Digital I/O
error messgae "VI_EVENT_PXI_INTR" undeclared identifier
I am writing my code for the PCI-DIO24 in C. I am trying to enable interrupt. When I configure my function as "viEnableEvent (panelHandle, VI_EVENT_PXI_INTR, VI_QUEUE,VI_NULL)"; I get an error saying "VI_EVENT_PXI_INTR": undeclared identifier. I use the visa 3.01 with new patch file.
(3,650 Views)
Samy,
You may want to consider posting your question to the Driver Development Kit (DDK) Discussion Forum. Since you are using register-level programming, that forum will probably be of more use to you.
Good luck with your application.
Spencer S.
(3,650 Views)
Samy:
Since PXI is not officially part of the main VISA specification, you have to #define NIVISA_PXI before including "visa.h" to get access to those symbols.
Dan Mondrik
(3,650 Views)
Thank you very much for your help.
(3,650 Views)
