Digital I/O
front panel
dear sir i did three three different program
in my main front panel i am decided to keep three tab and when i click the first tab in the main front panel, first program should run and the front panel for the particular program have to be displayed and when i chick the second tab second program have to displayed and so on ... i am new to the labview can you tell how to program like this  ....
wit regards
sathish
(3,455 Views)
Use Tab control (Modern -> Containers -> Tab Control) located in the functions pallette.
You can use tab controls to overlap front panel controls and indicators in a smaller area. A tab control consists of pages and tabs. Add front panel objects to the pages of the tab control and use the tab as the selector to display each page.
Sahil Singla
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(3,430 Views)
