Digital I/O
hardware compare issue - PXI-6552
Hi!
I'm using a PXI-6552 DIO module for testing SDRAM chip.
I'm not sure about hardware compare operating. I'm using a sequence of 0 and 1 to drive the tester during write command and H/L as expected responde with read command.
Does the H/L response data puts the driver to high impedance?
The problem is that also when i skip the write command I retreive (fetch) the response data correctly.
Thank you!
MM
(5,929 Views)
Hi Pic,
maybe this example can help you:
http://zone.ni.com/devzone/cda/epd/p/id/3401
Let me know,
bye!
(5,878 Views)
Thank you for the answer!
My configuration is a little bit different because I use the D0..D7 lines as bidirectionl lines.
I noted that the system works while the clock frequency is below 25 MHz, but i don't know why.
Has anyone tried to use this module above 25MHz?
Thanks a lot!
MM
(5,876 Views)
Hi Pic,
can you please attach the VI you use for acquisition and comparation?
Thank you,
bye.
FBM
(5,867 Views)
