Digital I/O
help controling a rc servo with a cRIO
I have run 5 volts through the Vsup, and the scope shows the same "offset" as with 7v.  The pulse is created but its only goes from about 2.5 v to 5 volts.  The power coming out of the 9474 to the servo is about 5 volts,and I got a reading of ~ 2.8 V coming out of the DO port to the servo.  It appears as if there is an offset almost, because I can change the input voltage and the peek rises but the base of the pulse stay still at abotu 2.5V.
Andy
Message 11 of 15
(2,592 Views)
Andy,
I'm working on getting a project going here.  If I can confirm that this isn't expected behavior, you will have to call in and return your module for repair.
Thanks!
Message 12 of 15
(2,577 Views)
Thanks with your help so far Brian,
I have gotten it to work with a FUTBA servo so I am going to adjust my project to use FUTBA servos for now and keep this in mind for the future.  However, I do not think that the module is broken since it works fine expect with the Hitec servos are attached.  If I have time in the future I may try and trouble shoot this problem.
Andy
Message 13 of 15
(2,575 Views)
I have created a simple FPGA program that just writes T then F to DO0.  I was able to have the card produce a 0 to 5 V square wave with a 5 V input.  If you place the negative terminal of a multi-meter on COM (pin 9 on the 9474) and the positive lead on DO0 (pin 0 on the 9474) and it does not get close to zero, you have a broken card.  I have attached the project that I used for debugging.
Your other servo may be working because it uses a non-TTL spec signal.
Message Edited by Brian R on 08-02-2007 04:11 PM
Message 14 of 15
(2,578 Views)
I ran the code you sent me and I got 5 volts out.  I think it has something to do with the fact that the modules says you should only use a sinking device with it.  I have tried pulled down resistors and a few other ideas which gets it close but not working  correctly.
Andy
Message 15 of 15
(2,554 Views)
