Digital I/O
how can the DI be configured individual​ly
hi,
i'm student in university of hsin hua in taiwan. i use the care PXI 6723. i try to have FF with digital input but it's imposible.
i want to coverter the input value to decimal number
can you help my???
thank you.
(3,593 Views)
hi,
can you help my???
thank you.
(3,591 Views)
It's certainly not impossible. Would you at least provide the programming language and attach your code with an exact description of your problem.
(3,589 Views)
hi,
i want to converter DI TO AO.
in the program in data in i have put just 1 bit by bloc, then i multiply bit*2^x.
but i have a problème,that when i connecte the connector box to the carte, the value of DI is AD(it force P0.1,P0.4,P0.6 to zero), when i leave it it the value is FF, i don't know why??
thank's for your aide
(3,582 Views)
