Digital I/O
how do i read a data-dump on the RS232
I am a new user.
I have an instrument that logs Temperature and Humidity. It was an RS232 interface.
I am using the Instrument I/O assistant to read in the data. Unfortunately this instrument dumps the data as soon as it gets plugged into the serial port.
The Instrument I/O reads a good part of the data and then crashes (error: A framing error occurred during transfer.   VISA Status code: bfff006b)
I am not sure where to go from here.
I changed the setting on the port… that did not help.
I had the Instrument I/O scan for a longer time..... No change.
Any suggestions???
Thank you
Gio
(3,968 Views)
Hello Gio,
It looks like you are receiving a framing error.  The error description is:  VISA:  (Hex 0xBFFF006B) A framing error occurred during transfer.
This knowledgebase, KB 3JFBMM6K: What Does Framing Error in Serial Communication Mean?, describes what a framing error is and what to do about it.  Please let me know if you have any other questions!
Meghan
(3,951 Views)
