Digital I/O
how to connect two digital input data into 1 waveform chart
i need help here.
i am working on digital data input using the DAQ-card.
The objective is to show the digital data on waveform chart, as in HIGH(1) and LOW(0) according to my input.
I managed to use the DAQ-card and showed the digital waveform chart for only 1 input, however,
when i tried to use 2 digital data input, the waveform chart only can show 1 single waveform only.
It failed when i tried to connect two input into 1 single waveform chart.
The error message is
"This wire connects more than one data source."
So, i need help here.
How can i connect to digital data input into 1 single graph? so that i can acquire two input and show the two digital waveform lines in 1 chart.
help needed..
Message Edited by noob on 08-25-2009 05:33 AM
(3,912 Views)
Press Ctrl+H to open Context Help, and point your cursor to waveform chart.
Context Help window will show how to wire multiple data to waveform chart using build array function.
(3,891 Views)
i tried this method already.
but it doesnt help much, cz the context help is just point out the error, but it doesnt sugest on how to solve it.
(3,886 Views)
Can you show me how do you write your code?
I don't believe the problem is not solved, if you follow context help.
(3,881 Views)
