Digital I/O
how to connect yokogawa wt3000E with labview using USB
    I'm working on a project, i need to interface Yokogawa WT3000E with Labview 2013 using USB Interface, I have downloaded labview driver for yokogawa and USB Driver, I searched through the net and found that WT3000E needs .inf file for interfacing, I created .inf file using NI-Visa, But in Visa Resource name i was not able to find it. Suggest me wth a solution.
(5,471 Views)
When i tried to create .inf file, i'm getting an Error in NI_VISA. Wheras in Labview Visa Resource Name i'm getting an Error (Class Conflict).
(5,466 Views)
The WT3000 cannot be used in the 'normal' way with the USB interface.
Install the driver that is in the attached ZIP.
The broken wire is caused by a incompatible VISA control. Create a new one if this error persists.
Kees
btw. this message should be posted in the Instruments board.
(5,453 Views)
Hi,  Thanks for the reply.I have Successfully interfaced Yokogawa WT3000E with labview. But,  when i run my .VI ,sometimes i'm getting an Error,  Instrument reports: 410,"Query INTERRUPTED;" 0,"No error". How to rectify this Error???
(5,433 Views)
Usually, that error happens when you send a command before a read is complete.
(5,427 Views)
Are you sure you are using the WT correctly ? Check how the the examples are working.
Can you post your VI here ?
Kees
(5,406 Views)
