Digital I/O
how to read analog inputs.
Iam using DAQ 6071E.I configured 32 channels for analog input.I want to read these analog inputs from all the channels at a time.I have seen in example VIs but they are for single channel at a time.any examples are welcome.
(3,319 Views)
Hope this VI helps.
I'm assuming that you went through the DAQ config and created names/settings for all the channels. You should be able to just drag and drop them into this VI. I'm sure you will have to alter the buffer settings.
Let me know if it works.
Chances are if you have seen VI in the forest it hasn't fallen.
(3,315 Views)
