Digital I/O
how to turn off the LED
hallo
I have a problem , I put a LED as a warning, it turns on when no axis is selected.
It works, but the problem is , the LED stays on even if  i select an axis.(see attachment)
is there any way to turn it off at the begining and while  the LV is runing
thank you
Toni
(3,648 Views)
When running the VI, the value of axis will be compared to 0 :
  • equal : outer True case --> LED = True
  • different : outer False case
The only place where you write the state of the LED is in the True case and therefore it will never be reset.
Could you please explain a little bit more in details what you are trying to do. This would help us to make an example.
(3,640 Views)
thank you for your replay
OH I  see.
I put the LED outside the case , and so it will be reset everytime I start the prog.
thanks again
(3,638 Views)
