Digital I/O
how to use USB 6501 to record analog voltage readings
I have never used ni products before and I just started a project to test battery cells, the USB 6501 was recommended for taking voltage, current and resistance readings which I bought, now I can't seem to get it to function properly.  HELP PLEASE.
(2,734 Views)
How far did you make it?  What version of DAQmx did you install?  What programming environment are you trying to use?  Have you messed around with MAX (Measurement and Automation eXplorer)?
(2,721 Views)
Thanks for replying, I have been playing with the DAQExpress and have not messed around with MAX (Measurement and Automation eXplorer), I didn't know it was an option.
(2,716 Views)
