Digital I/O
how to use second ni6534 to make 64 bit parallel digital I/O possible
I have installed 2 NI6534 cards to be able to write 64 bit data. I have connected the two NI cards using the flat cable connections. But how do I make the cards write 64 bit data ? Can you please give a small example.
(3,191 Views)
Hi Jaap,
The trick is to use the RTSI Connect VI. This, combined with a RTSI cable, allows you to share the clock between the two boards effectively making them appear as a single 64 bit device. Here is an example program.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E18956A4E034080020E74861&p_node=DZ52336&p_source=External
I hope this helps!
Russell
http://www.ni.com/support
(3,191 Views)
