Digital I/O
i want (DIO Port Config.vi)does any one have it?
i have a VI that tries to call (DIO Port Config.vi), (DIO Port read.vi), and (DIO Port write.vi).
it was running before but now it just can't find them anymore on my PC. Any one have it?
(5,746 Views)
Hello Tito,
All three of those VI�s are located in a library called zadvd.llb at the following location:
C:\Program Files\National Instruments\LabVIEW 7.0\vi.lib\DAQ\ZADVD.LLB
They are installed when NI-DAQ is installed. You may need to reinstall NI-DAQ if they have been deleted.
If none of these suggestions help, please post your installation history of LabVIEW and DAQ, the software and versions you are using, and any other information that may help, and I�ll be happy to look further into it.
Have a nice day!
Robert M
Robert Mortensen
Software Engineer
(5,746 Views)
I have a similar problem. I installed Labview 7.0 and there was something in the program (somebody sent the program to run) that required 7.1. So we purchased that one for an expense and now it calls for DIO Port Config.vi
We installed NI-DAQ Legacy also but the said folder DAQ never appears. I got the zadvd.ll file from the internet but then some other error starts coming up.
How can I get DAQ folder in my Labview 7.1/vi.lib folder?
Thanks in advance.
P.S. We are a biology group trying to run a code given to us and find these things a little daunting, so kindly explain in layman's terms.
(5,231 Views)
The installer must have put the files somewhere. The folder should be called DAQ and it would be located in the vi.lib folder under LabVIEW. Check your 7.0 folder or just use windows to do a search. If you still fail to find the files, try reinstalling.
You can confirm the installation worked by looking in MAX (Measurment & Automation Explorer) and expanding the software listing.
(5,223 Views)
