Hello Eduardo,
It all depends on what type of application you are going to do after measuring your pulses. For example, if you want to see the state of the pulses, acquire a digital pulse, or do applications like change detection, then you can go for a digital board. If you want to applications like count edges, pulse-width measurement, period measurement, semi-period measurement, freq measurement, position measurement or two siganl edge separation measurement then go for a counter/timer board.
Hope this helps,
LA
