Digital I/O
interrupt on change on dio96
Hi All;
 Is interrupt on change of state supported under Linux ( via the newest daqmx)? We really could use that feature.
Pat
(3,954 Views)
Hi Pat,
DAQmx 8.0 for Linux supports change detection. However, the PCI-DIO-96 does not support change detection. Here is the link to a knowledgebase which lists the devices that support this feature: Which NI DIO Devices Support Change Detection?
Hal L.
(3,939 Views)
Hi Pat,
You could consider the NI PCI-6509. It offers change detection, 96 digital input/output lines (same as PCI-DIO-96) and has 24 mA current drive (10x )
(3,932 Views)
(3,927 Views)
