Digital I/O
is it possible to control four 8 bit-port from P0 32bits in PCI6229 ?
I'm going to replace PCI6025E to PCI6229 due to EOL of PCI6025E in our tester. In PCI6025E, these are one DIO0-7 port and three 8bit-port that are used in our tester. I'd like to set the same from for PCI6229,too. and My question is ,as tthese is one P0 32bit-port @PCI6229, is it possible to control four 8 bit-ports from P0 32bit-port ? Pls tell me about the above. PS the used software is VC++ and Daxmx. PC is window-7
(2,064 Views)
You can setup and control each digital line individually on 6229 as stated in below link.
https://www.ni.com/documentation/en/multifunction-io-device/latest/pci-6229/pinout/
Hence, in your application you can have "virtual" ports for desired digital channels.
(1,861 Views)
