Digital I/O
led matrix control by using pwm
Dear Joseph,
This program work.
Thanks for kind help,
Can I store different duty cycle value for each digital output channel.
I will do few modifications in this program for actual purpose,
I gives you feed back again.
Rajesh
Message 11 of 24
(2,781 Views)
Dear Joseph,
This program work.
Rajesh
Message 12 of 24
(2,780 Views)
Hi Rajesh,
I'm glad it works.
This was only meant as a starting point to give you the general idea. You can obviously adapt to have a different duty cycle for each channel. I would suggest simply creating an array with all the various duty cycles and to only use the one corresponding to the current channel being written to.
Good luck!
Message 13 of 24
(2,777 Views)
Dear ,
it is very interesting discussion. I have similar idea to do. But I use Labview 8.2.
Joseph, can you please post the vi with Labview 8 version?
Thanks.
Shin'ichi
Message 14 of 24
(2,687 Views)
Hi Shin'ichi,
here is the LV8.2 version.
Message 15 of 24
(2,674 Views)
Great! Thank you very much.
Message 16 of 24
(2,658 Views)
Dear Joseph,
This my program working very accurately, but during measurement i am facing one problem, that suppose i wants to start measurement from forth LED(forth LED array). but for this i need to run all program and wait till the signal from forth LED come.
many time i wants to start measurement from middle any LED(say LED11) not from the first LED (means i don't want to measure signal from first 10 LED, for this i have to put zero duty cycle for all previous 10 LED and start measurement from LED 11 and its very time consuming)
for this i tried to make changes in program like,
suppose i click on any LED(may 1, 2 3,...) on the screen then these LED will be continuously ON(for given duty cycle) till next command/execution or when i click again on the same LED it will be OFF.
Each LED will be work independently to each other.
please Joseph can you help me to resolve this problem
Message 17 of 24
(2,344 Views)
Hey,
have you tried changing the first state of the state machine to a control on the front panel, so that before starting you can choose which state will execute first?
To do this, right-click on the enum before the state-machine, and select 'change to control'.
Then before starting the program, choose the first line or column and all the ones before that will be skipped.
I hope this helps.
Message 18 of 24
(2,315 Views)
Dear Joseph,
I did as per your suggestions but not work, it shows following block diagram error,
"You have connected an indicator to an input of Sub Vi. Change the indicator to a control"
Error details are
"A wire must be connected to one and only one data source, such as a control's terminal or a function output. This wire is connected to two data sinks but zero sources. You must add a source, perhaps by changing an indicator to a control."
 Best Regards,
Rajesh
Message 19 of 24
(2,308 Views)
please change the indicator you created to a control as the message states. You have two outputs connected together.
Message 20 of 24
(2,306 Views)
