Digital I/O
linux with USB-6501 - no devices found
I cannot see devices after installing the drivers.
No idea where to look now.
Trying with python:
local_system = nidaqmx.system.System.local()
driver_version = local_system.driver_version
print('DAQmx {0}.{1}.{2}'.format(driver_version.major_version, driver_version.minor_version,driver_version.update_version))
outputs:
DAQmx 21.3.0
So I think drivers are installed successfully. When trying to read some levels:
with nidaqmx.Task() as task:
task.ai_channels.add_ai_voltage_chan("Dev1/ai0")
task.read()
I get output:
nidaqmx.errors.DaqError: Device identifier is invalid.
Device Specified: Dev1
I cannot see any devices, output of nilsdev command is empty. I tried various device identifiers.
lsusb shows the device is connected:
Bus 001 Device 002: ID 3923:718a National Instruments Corp. NI USB-6501
modules loaded:
nipxirmk 303104 1
nimru2k 774144 2
nimxdfk 593920 4 nimru2k
nidimk 376832 5 nimru2k,nipxirmk
nimdbgk 466944 6 nimru2k,nipxirmk,nimxdfk
niorbk 122880 5 nimdbgk,nimru2k,nipxirmk,nimxdfk,nidimk
nipalk 1241088 9 nimdbgk,nimru2k,niorbk,nipxirmk,nimxdfk,nidimk
nikal 126976 7 nimdbgk,nimru2k,niorbk,nipxirmk,nimxdfk,nidimk,nipalk
ni_usb6501 16384 0
kernel version:
5.13.0-37-generic
dmesg
[ 4.812858] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[ 4.964832] usb 1-1: New USB device found, idVendor=3923, idProduct=718a, bcdDevice= 1.00
[ 4.964857] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.964866] usb 1-1: Product: NI USB-6501
[ 4.964873] usb 1-1: Manufacturer: National Instruments
[ 4.964879] usb 1-1: SerialNumber: 0201B133
What am I missing now?
(1,704 Views)
Led in device is blinking ~2x second, so I think I'm using the API completely wrong.
(1,671 Views)
Stuck with this error:
task.di_channels.add_di_chan("comedi0/line0/port0")
task.read()
Device Specified: comedi0
Task Name: _unnamedTask<0>
Status Code: -200220
I've tried various names for device (Dev1, Dev2 and so on), no success.
Any hints where to look?
(1,645 Views)
