11-07-2023 01:33 PM
I'm reading the spec for the PCIe-6351 and it has 24 mA max listed for P0.0...7. Is that per pin or for all 8 outputs?
Thank you,
Ron
Solved! Go to Solution.
11-07-2023 06:50 PM
The following specs are per-channel (NI calls out explicitly if the spec changes based on the number of active channels or if it is shared).
