Digital I/O
muliple number input to PCI 6534 pattern trigger
I need to create a digital pattern for the PCI 6534 data pattern trigger input (I32) but I am using multiple numbers as the pattern that I believe needs to be converted into their digital pattern form in 8 bit sequences, for example 2,3,2 equals 00000010, 00000011,00000010 and would append together to be 000000100000001100000010
I am not very familiar with the pattern trigger input specification and have had no luck in finding reference inforamtion.
(3,192 Views)
Hi Bob-
It sounds like you are trying to perform pattern match triggering on your PCI-6534.
This type of triggering is meant to start or pause an acquisition based on a single pattern at the specified input lines and not for a pattern of inputs as you seem to be indicating.
Are you using LabVIEW or another API? There is a great example for LabVIEW in the NI Example Finder that can be found by choosing Help>>Find Examples and then browsing to Hardware Input and Output>>DAQmx>>Digital Measurements>>Read Dig Chan-Int Clk-Pattern Match Start.vi.
If you're using CVI or other C development similar examples are available at this location.
A discussion of the pertinent trigger function can be found in the DAQmx C Function Reference Help on your Start>>Programs>>National Instruments menu. A search for "pattern match" will turn up information on the three trigger types applicable to the pattern matching capabilities of your board.
I hope this helps!
Thanks-
Tom W
(3,180 Views)
