Digital I/O
ni-4472
How do i determine what my Nyquist frequency is when using a NI-4472?
(5,607 Views)
What is the bandwidth of the signal you are trying to sample?  Nyquist says you have to sample at at least twice that frequency to be able to recreate it.  I recommend sampling more like 5 to 10 times the signal to get a nice data capture.
GCentral
(5,603 Views)
i am sampling from 100 - 10000Hz and my sample rate is 45000Hz
(5,600 Views)
Max signal frequency is 10kHz and you are sampling at 45kHz?  That sounds like a good setup to me.
GCentral
(5,588 Views)
