Digital I/O
ni 9381
Does anyone know the value of the resistor inside NI 9381 for the DIO or else what is the short circuit current from the digital output. NI manual for NI 9381 is silent on it and does not specify current rating except for specifying output logic voltages at 100uA current. Can someone provide some information on current output ratings for the digital output of this DIO part of the multifunction module NI 9381
(5,173 Views)
Hi romicanada,
It looks like you also have another post here for the same issue.  In the future, it might be in your best interest to try to keep to one subject board in case the conversation becomes split.  Additionally, in the case someone else has the same question as you, it will be easier for them to find responses.
Chris H
(5,124 Views)
