Digital I/O
ni-9477 controlling a digital input with an NPN config
I have a 9477 that I'd like to use to enable a VFD which is configurable as NPN or PNP:
I understand that using the PNP config isn't possible without a relay or more EE than I am familiar with.
If it were a mechanical relay (or just a wire), in the NPN config, pulling DI1 to GND (pin 5) works fine, but when I use the 9477 it doesn't work, likely because it needs some current? I'm not exactly sure, any insight?
(869 Views)
Accepted by topic author NXTenergy
Ok, so this actually works without anything else in the circuit. I had a configuration issue in the cRIO that was preventing me from communicating with the module while in scan mode (but not throwing an error, amazingly).
(851 Views)
