Digital I/O
ni-daq mx tools for matlab error message
i recently installed ni-daqmx tools. installation was fine.
when I started matlab (R2009b windows 32-bit), i got this message:
??? XML-file failed validation against schema located in:
C:\Program Files\MATLAB\R2009b\sys\namespace\info\v1\info.xsd
XML-file name: c:\program files\matlab\r2009b\toolbox\natinst\daq\info.xml
To retest the XML-file against the schema, call the following java method:
com.mathworks.xml.XMLValidator.validate(...
    'c:\program files\matlab\r2009b\toolbox\natinst\daq\info.xml',...
    'C:\Program Files\MATLAB\R2009b\sys\namespace\info\v1\info.xsd', true)
Errors:
org.xml.sax.SAXParseException: cvc-complex-type.2.4.a: Invalid content was found starting with element
'area'. One of '{MathWorksID, type}' is expected.
can anyone tell me what this means + how to fix it?
thanks
(3,869 Views)
(3,653 Views)
