Digital I/O
ni845x.dll installer error
I am trying to use an NI USB-8451 controlled by some Labview written (and proven to work) by a colleague. When I tried to run his code, I got an error saying I needed to install a dll: ni845x.dll.
So, I found the NI downloader for the Windows 7 64-bit version of that dll (I'm running Windows 7, 64-bit). When I try to run the downloaded .exe (NI-845x_212.exe) I get this message:
"The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher." But different versions for x86 and x64 are not offered.
What next?
(4,841 Views)
Hi Tom,
What version of LabVIEW are you using? Is it 32 or 64-bit?
If you are using LabVIEW 32-bit, try downloading the 32-bit version of the DLL and try again.
Jinfone
(4,809 Views)
Soved (I have 32-bit LabView). Though the version I had tried was indeed a 32-bit version, there is a later version:
NI-845x 14.0
This installed correctly and enabled me to use the USB-8451.
I found the full set of variants here:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:ndr/q/ni%208451/
(4,804 Views)
