07-21-2005 09:44 AM
07-21-2005 10:41 AM
@mlloyd wrote:
For receiving data from the third party device
- How can I make a matched impedance system?
 - The third party device has a 50 ohm series resistor, then the cable is 50 ohms, but does the PCI-6541 have the parallel 50 ohm resistor?
 - Would the 6541 be able to read a voltage that is half of 3.3V if it is set to run using the 3.3V logic family?
I think I've answered my own questions after looking at the detailed channel electronics information, but please let me know if I'm incorrect...
When I used another NI card, there were specific recommendations made for Schottky diodes that the peripheral device should have. Is there a specific diode a third party device should have when connecting to the PCI-6541?
07-22-2005 02:16 PM
09-14-2005 04:10 PM
@RyanB wrote:
Be aware of the 6541 output current limitation when driving a 50 Ohm load.
I max = V OH (max)/ (100 ohms) = 3.3V / 100 ohms = 33 mA,
09-16-2005 09:48 AM
Hi mlloyd,
You are doing your calculations correctly.
I would like to concentrate more on the termination scheme. The 6541 provides an output impedance that is very close to 50 Ohms, and the SHC68-C68-D2 cable is also matched to 50 Ohm characteristic impedance. In almost all applications you can generate data from the 6541 into a high-impedance load and your signals will be fine. Even though you will get reflections at the receiver, those reflections will be absorbed by the matched source impedance at the 6541. You wind up with signals that are still very clean.
In other words, you should be able to use high-impedance without sacrificing your signal quality.
I hope that helps,
Allen
