Digital I/O
pci resource pci-dio-96
I have inserted a PCI-DIO-96 in three different PCs riunning Windows XP.  In all cases the Device Manager does not show resources allocated automatically to the card.  It is recognised as being a "PCI card" but no further progress is possible - there is no data posted in the "properties" sections of the DM.  Does this suggest that the card is faulty?
Do I understand the installation procedure correctly - resource address allocation should be automatic?
(5,192 Views)
Did you install DAQmx?  DAQmx is the driver for NI's DAQ boards.
(5,189 Views)
No. I didn't think a driver is necessary for register-level software.  Is DAQmx easy to find on this huge wesite?  Thanks for your help.
(5,178 Views)
What register level software are you talking about?
Did you use the search - 'daqmx driver'?
(5,174 Views)
There should have been a disc that was shipped with the DIO card that has DAQmx.  If you do not have that, the latest version can be found here: NI-DAQmx 14.5.1
(5,170 Views)
