Digital I/O
playing a continuous waveform from the PCI-DIO-32HS with no LabVIEW, CVI, etc.
I'd like to always have a particular waveform playing, but without a giant memory hog in the background like a LabVIEW or CVI executable. Can this be done?
(3,190 Views)
Hi bmihura,
I would recommend building a program in LabVIEW, and then turning it into an executable. This would not take all the overhead, as it will only be using the LabVIEW run-time engine and DAQmx driver.
If you would still like to use C, C++, etc, you can program the 6533 (PCI DIO-32HS) using the Traditional DAQ or DAQmx function calls. I would highly encourage using DAQmx since you are starting from scratch. Once DAQmx is installed, you can find the ‘NI-DAQmx C Reference Help’ under Start » Programs » National Instruments » NI-DAQ.
David L.
Systems Engineering
(3,184 Views)
