Digital I/O
problem with C-RIO module...
Hey , i have a compact Rio with a module NI c-RIO 9472, module of digital output.
I have create a vi to generate three squared signal with a late of 120° between each channel.
My Vi is included in a message
My problem is a time problem because i can't have a signal with frequency more quickly as 10hz. But the module can generate 10khz signal.
Best regards
François
(3,934 Views)
I think the best way to generate your sqaure signal is to look at the example located in Help >> Find examples and then go to Hardaware I/O >>  cRIO >> FPGA fundamentals >> counters and then select quad_gen.vi.
You will ahve to invert the value generate don each line to obtain your square signal.
Regards
Alexandre D
(3,916 Views)
Hi ,
I am using NI C RIO 9012 system for my project. I installed Labview 8.2  and NI RIO drivers on my PC. When I want to configure RIO system from MAX with specified IP address , I couldnt do , I have message as " Unable to intialize connection to remote system". But this is working with my prof PC.
I also want to bring to note that intaially IP adress was  xxx.xxx.xxx.34 , now it changed to xxx.xxx.xxx.2. We are bit surprised how it possible.
We tried in all posibilties but unable to configure from MAX 😞
I use NI RIO 2.1 version.
Thougth the IP adress is changed, my Prof. is still connected but he didnt changed IP adress.
Can any help me to solve this problems.
Thanking you,
Dilip Gadipudi
(3,624 Views)
