Digital I/O
pxi 6515 output not working in NI Max
I am trying to test my pxi6515  digital io and i cant get it to output a voltage in the SCB100A terminal (P7.0 and P7.1) I am operating it through NI Max, Vcc is connected to 24V (pin 96) and ground to P7.GND (pin 97), . The digital input tests fine in NI Max.
Does anyone have an idea what the issue could be? Any settings i need to change? The pin numbers seem to be correct.
Cheerio, Peter
(3,084 Views)
Hola Peter,
All the 32 output lines form the 9515 are sinking, this means that you wont see a voltage at its output when it is turnned ON because it provides you with a path to ground.
With sinking outputs you should wire the +24Vdc to the device and the ground from the device to the output pin of the digital io card.
Of course I don't know how you connected the circuit, i'm just guessing
Hope this helps.
Saludos.
(3,000 Views)
Hi Antoniooh,
i feal really stupid now. I copied the wrong sectino of the manual, the one for the 9514 (sourcing). So thank you big time for answering even a stupid question.
Cheerio,
Peter
(2,985 Views)
NO, there are no stupid questions, we all make mistakes.
glad I could help.
Saludos.
(2,975 Views)
