Digital I/O
running two tasks simultaneously in vb
i HAve written this code in VB to simultaniously running two tasks 1.write to digital line 2. Generating pulse on Counter 0 PIN
its giving me error 200077 requested value is not supported value of this property
Option Explicit
    Private taskHandle1 As Long
    Private taskHandle2 As Long
    Dim sampsPerChanWritten As Long
    Dim data0(0 To 1) As Byte
    Dim data1(0 To 1) As Byte
    Private taskIsRunning1 As Boolean
    Private taskIsRunning2 As Boolean
Private Sub Command1_Click()
StopTask
End Sub
Private Sub startCommandButton_Click()
    data1(0) = 1
    On Error GoTo ErrorHandler
    startCommandButton.Enabled = False
    DAQmxErrChk DAQmxWriteDigitalLines(taskHandle1, 1, True, 10#, DAQmx_Val_GroupByChannel, data1(0), sampsPerChanWritten, ByVal 0&)
    taskIsRunning2 = False
    DAQmxErrChk DAQmxCreateTask("", taskHandle2)
    taskIsRunning2 = True
    DAQmxErrChk DAQmxCreateCOPulseChanFreq(taskHandle2, "Dev1/ctr0", "coChannel", DAQmx_Val_FrequencyUnits2_Hz, 0, 0#, 2500, 0.5)
    DAQmxErrChk DAQmxCfgImplicitTiming(taskHandle2, DAQmx_Val_AcquisitionType_ContSamps, 1000)
    Exit Sub
ErrorHandler:
    If taskIsRunning1 = True Then
        DAQmxStopTask taskHandle1
        DAQmxClearTask taskHandle1
        taskIsRunning1 = False
    End If
    startCommandButton.Enabled = True
    MsgBox "Error: " & Err.Number & " " & Err.Description, , "Error"
End Sub
Private Sub StopTask()
    DAQmxErrChk DAQmxStopTask(taskHandle1)
    DAQmxErrChk DAQmxClearTask(taskHandle1)
End Sub
Private Sub Form_Load()
    data0(0) = 0
    DAQmxErrChk DAQmxCreateTask("", taskHandle1)
    DAQmxErrChk DAQmxCreateDOChan(taskHandle1, "Dev1/port0/line8:8", "", DAQmx_Val_ChanForAllLines)
    DAQmxErrChk DAQmxStartTask(taskHandle1)
    DAQmxErrChk DAQmxWriteDigitalLines(taskHandle1, 1, True, 10#, DAQmx_Val_GroupByChannel, data0(0), sampsPerChanWritten, ByVal 0&)
End Sub
Private Sub Form_Unload(Cancel As Integer)
    StopTask
    End If
    End
End Sub
Can Any body help me with this code
Message 1 of 1
(4,154 Views)
