Digital I/O
sawtooth waveform pattern
Hello all, does anybody know what the value of 12bits sawtooth wave test pattern? thanks.
pat
(3,391 Views)
What is the output? digital or analog, 12 bits or 16 bits? Probably the easiest way is to simply keep an unsigned - 16 bit counter in memory, incrementing it by 4 bits (16) each time increment and putting out the upper 12 bits. The output will increase by 1 bit each time period, and you'll get the saw-tooth edge when it rolls over.
(3,391 Views)
Could you give us more information about the signal you need to generate?
Regards
Filipe A.
(3,391 Views)
