Digital I/O
sb Rio 9605 ADC readout
I want to readout an ADC with the sbRIO9605. For this I need a 10MHz clock and 5ns pulse as chipselect for the ADC.
The problem is now, that I am working with two timed loops. One loop is to create the clock and second for the chipselect. But if I would start the programm now, I would see that those two loops are not running synchron.
How can I fix this?
Does anyone has an idea?
(4,179 Views)
Use one loop, and add extra logic or timing vi's to create the delays between rise/fall. You should not need two loops.
(4,134 Views)
