03-19-2015 07:44 AM
Hi all!
I try to read data for 1-wire sensors (ds18b20, ds2411)
I use component from https://decibel.ni.com/content/docs/DOC-24136
If 1-wire sensors connected to J503 DIO read data no problem
No read data from Mezzanine Card (RMC DIO)
I checked the connections, wire, results no found :mansad:
How i fix it?
Thanks!
03-20-2015 04:29 PM
Hi swd1986,
Could you please clarify what your setup is as well as what the error that you are receiving is? How is all of your hardware set up? What board is giving you the error?
