Digital I/O
shorter digital output pulses
Hi all,
I'm using the output pins of the 7344 - board. Depending on the movement of a xy - stage (controlled by the motion controller) I'd like to trigger a laser pulse. Unfortunately the output pulse has a length of about 20 ms and so I have to decrease the speed of my stage rapidly (otherwise the pulses will overlap).
Is there a way to control the length of these pulses? I'm using the library "flex_set_port".
Thanks in advance for your help.
Martin
Message 1 of 1
(3,145 Views)
