Digital I/O
speed of pci dio 32hs
hi...
can anybody tell what max speed can be attained for continuously acquiring digital audio data using pattern i/o.the card i m using is PCI DIO 32 HS.
please help.
regards
vivek modgil
(3,515 Views)
Hello Vivek.
Thank you for posting to the NI Discussion Forums.
The maximum sampling rate for the DIO-32HS card (also known as the 6533) is 20 MHz.  This information can be found on page 94 of the User Manual for this card, which can be found at:
NI 653X User Manual
http://www.ni.com/pdf/manuals/371464d.pdf
Have a great day!
Brian F
(3,494 Views)
thanx Brian..
well i have read in some other trhread on this forum that the max speed that guy attained using the same card is 10khz ,that is why i posted the thread because i want min. speed of 1mhz to acquire audio data.....
(3,485 Views)
