Digital I/O
switch between inputs and outputs of DIO 650x using DAQmx API
We need to switch 2 ports (16 lines) of our DIO 650x from input to output and vice versa.  We want to use the DAQmx C-API for that task.
What steps are needed to this ? Is
Stop task
Either Create DO Channel or Create DI Channel
Start task
OK,  or are there additional steps necessary.
(3,117 Views)
Hi Markus,
you also have to create a new task for switching between read/write operation on the same port. So it's not enough to stop the task, you should clear it and reinitialize with the same channels after that.
Have a look on the DAQmx examples Read/Write from/to digital port on your local folder, that should give you more insight in DAQmx programming with the C-API:
C:\Programme\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\
regards,
Nikolai
(3,098 Views)
