06-21-2005 09:51 AM
06-22-2005 11:00 AM
06-22-2005 11:30 AM
06-23-2005 08:35 AM
02-06-2006 02:40 PM
Hi Allen -
I am in the same situation. I have two PCI 6541 cards. All the channels on one card are devoted to generation. The second card is split with 16 generation and 16 acquisition. I have a RTSI cable connecting the cards. I am trying to get all the generation and acquisition sync'ed. My case is simple because all devices are at the same sample rate. I can successfully use TClk to setup up both of the generation sessions. But I run into trouble when I add the acquisition session. The TClk functions don't like to have two sessions on the same card. When I try to follow the examples you suggest, the TClk_Initiate returns an error if I have initiated the Acquisition session:
Error -250034: NI_TClk initiated a session, and the instrument driver reported an error.
Also, the example you mentioned made use of external connections. I would like everything to work over the RTSI with no external clock or trigger connections if possible.
Thanks! Gil
02-08-2006 01:55 PM
It looks like the last post was made in two locations. Please go here to reply to Gil's post.
Ryan M.
