Digital I/O
timeOutError = -10800
I have the error message timeOutError = -10800 all the 518 patterns generated. What to make?
(3,270 Views)
Do you have a simple example of code which reproduces your issue? So that you can post it here and I will try to understand this behavior. Tell me also exactly what is your programming environment, driver version, and hardware used. Do you know the name of the function which generates the timeout error?
Thanks in advance for all the details.
Matthieu Gourssies
(3,270 Views)
