Digital I/O
traditional NI-DAQ functions for NI-DAQmx
Are there suitable NI-DAQmx_Functions instead of the traditional DAQ-Functions:
Init_DA_Brds
DIG_Prt_Config
DIG_Out_Port
DIG_In_Port
DIG_Out_Line
DIG_In_Line
thank you
(4,196 Views)
In the new DAQmx API digital inputs and digital outputs are accessed via Tasks in the same way as analog inputs and outputs.
So you would first Create a new task, then configure the task (in your case configuring which lines or ports you want to read from/write to) eventually configure the timing, and afterwards you can read/write the task. You can use the DQmx-Assistant, too.
Because you have not named your Development Environment, I could not include concrete function or VI names.
Check out hte example library of the developer zone, you will find examples for Digitla I/O with DAQmx there.
http://search.ni.com/nisearch/nisearchservlet?nistype=default&ddown=3&filter=%2Btaxonomy%3A%22Example+Code%22&q=Daqmx+Digital
(4,188 Views)
Hi there
I m writing an program in Visual Basic 6.0 using DAQmx driver 8.3. I would like to convert the traditional DAQ into DAQmx. I have the following functions in traditional DAQ
1) DIG_IN_LINE
2)DIG_OUT_LINE
3)DIG_CONFIG_LINE
Can i get the equivalent function in DAQmx?
(3,958 Views)
