Digital I/O
triggering with PCI-6509 (C language programming)
I'm completely new to the digital acquisition data devices. I need to trigger an IEEE 1394 camera through the PCI 6509. I'm programming in C. Is there any example that could show me what shall I do? Could someone tell me what are the steps or the documentation I should check in order to start?
Thank you
(3,706 Views)
Hello donatap,
Take a look at the example folder of NI-DAQ:
C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC\Do
In this folder all kinds of examples are listed on how to do Digital Output. Maybe this can help you understand the driver better.
Hope this helps.
Best Regards,
RikP
Application Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(3,706 Views)
Dear RikP,
thank you but I had already tried to run those examples, without succeeding. In fact, everytime I run one of them, I get the error message you can find in the attachment.
Provided that I'm using an Ni board (the PCI 6509) and I have the right version of the driver (NIDAQmx 7.2), the only thing that remains is that I'm not configuring properly the device through the Measurement & Automation Explorer.
At this point, I don't understand what shall I do, since I follow the instruction in the help in order to configure the device.
Do you know what can be the problem?
Best regards
(3,706 Views)
