Digital I/O
two independent pci6517 cards control one load
As shown in the drawing, two independent cards control one load. Neither one is set high at the same time. If DO of card1 is high whlist DO of card2 is low, will there damage to DO of card2? Is the wiring applicable?
(4,760 Views)
Probably you should have a gate where you should connect both the DO so you can use Either one of it. Are you using a gate? I don't see one! If you are simply connecting DO's to a junction then it would damage the hardware.
(4,747 Views)
Yes, I am not sure if a gate is needed, so I'm asking whether I need a gate or not when using the sink-mode pci6517.
(4,745 Views)
I would use a gate, or put a diode on each of the lines to be safe.
Peter C.
(4,729 Views)
What you diagramed is fine in theory, however, depending on a host of items, including whether the two daq cards are in the same computer chassis, you could be setting up a time bomb. Industrial installations typically take their 120 vac mains power from 3 phase distribution systems, and if your cards are in computers supplied from a different leg of the 3 phase supply, or even a different distribution transformer (if they are some distance apart, this is entirely possible, but can be the case even for side-by-side outlet strips), you can have some extreme differences in the ground potentials of the chassis. I know they are all supposed to be referenced to earth/building ground, but dependiing on how diligent the installing electricians were, you can get 30 to 50 volts ac from one ground to another! You would be amazed how often this happens.
Given all of the above, and there are many more situations with the power electrics than can cause your situation grief, I would use opto-isolators ont BOTH outputs, and a single output power supply for the load device.
I am not blowing hot air here. About 20 years ago, I blew out almost every piece of test gear on a service bench under the conditions described in my first example. The only things that survived wre the batter-operated testers, not connected to the bench ac power supply.
Be warned.
Good luck,
Dave
(4,703 Views)
