Digital I/O
unable to run this program continous loop
i have developed a program to postion probe drive using stepper motor. in this program m calculating pulses required to given to stepper motor and then using daq m generating the pulses, but i am not able to run my vi in continous mode, i need to stop it to repeat motion. kindly, someone help me to get in continous mode.
(5,454 Views)
have you enclosed your code in whilel loop for if you just make the logic and press run it will run only once. i have LV 8.5 so yur post is not going to open in my LV.
(5,292 Views)
