Digital I/O
usb-6501 digital output
I am having trouble with the basic DAQmx assistant in how to create a simple vi that will be able to compare user inputted values and output either high or low to a pin.  I am using usb-6501 and was wondering if there was a basic tutorial or sample code to output a digital constant or signal.
(3,262 Views)
See Getting Started with DAQmx and Help>Find Examples.
The comparison has nothing to do with the 6501 unless you are comparing digital inputs from it. And when you say you are having trouble, please provide some actual details. Error codes for example. Posting at least an image (no bmp and code is better) will also help see what your problem is.
(3,259 Views)
