Digital I/O
use PCI-6602 to produce synchronous different TTL singals
I am using PCI-6602,if I want to use two line to producing two different TTL singals,and the two TTL singals must write to lines synchronously.How can I get it,Thank you !!
(3,139 Views)
You can generate two pulse trains, one on each counter. If this is what you need, you can do that easly with pulse generation VIs - you can look at the LabVIEW shipping examples - in particular, look at Generate Pulse Train (NI-TIO).vi
RamziH.
(3,139 Views)
