Digital I/O
use a VI code into Visual C++
I have on one side a camera read with visual C++.
On the other side, I have a mirror controled by Labview. I want to insert the VI mirror controle code into Visual C++.
Is it possible to compile the VI code into DLL and call it from Viusall C++ ? With application builder it may be possible but i do not know if it works for DLL that supposely send data into a PCI6025E card.
N-
(3,346 Views)
Hello Blate,
you can approach the power of LabVIEW to acquire, analyze and present data and then to create a DLL for using from other programming language.
I send several links where you can find how to create a DLL and how to call it form Visual C++.
http://zone.ni.com/devzone/conceptd.nsf/webmain/e77df3dd07dfb73b86256cbf00780c96
Other links:
http://zone.ni.com/devzone/conceptd.nsf/webmain/51523dcdef6c9a8d862569060074fd90
http://zone.ni.com/devzone/conceptd.nsf/webmain/7d6a20fe02edbf318625690700704cf3
http://zone.ni.com/devzone/conceptd.nsf/webmain/5DF85B448EB081D8862568FF006A0B20
Moreover, you´d have to instal NI-DAQ to communicate with the PCI6025 and you need the labview runtime to execute the DLL or distribute the application
I hope this helps you
Regards
Diego M.
(3,329 Views)
OK Great,
I just need application builder now.
thanks a lot,
N-
(3,322 Views)
