Digital I/O
user defined sequence
I'm looking to create a program in Labview that has the user create a sequence then for labview to play it back.
For example:
There are 5 LEDs.
A simple pattern the user makes is, first LED on for 2 seconds, pause 1 second, 3rd and 4th LED on for 3 seconds.
I'm not sure exactly how to start. Any feedback would be great.
Thanks!
(4,754 Views)
Could you elaborate a bit on what you mean by having the user create a sequece? Also, could you explan a bit more on what you mean by having LabVIEW play it back? You might be able to create a main vi with a state machine that calls a sub vi. You might look at the State Machine Fundamentals.vi as a starting point, you can find in in LabVIEW by going to Help>>Find Examples.
Good luck!
(4,728 Views)
