Digital I/O
using crio9004 with digitalI/O 9403 to read I2C
Hi every one,,
i want to read my gyro sensor using cRIO9004 and the module NI 9403
is it possible to do so ??
can i have any tutorial or guide to do so ??
thanks
(6,256 Views)
I also want to connect to i2c using NI 9403 ans cRIO 9076
did you manged to do it?
I know that you need to add pull-up ressitor and install i2c driver API avilable online
https://www.ni.com/en/support/downloads/tools-network/download.spi-and-i2c-driver-api.html
also ther is possible way to use full fpga soloution example
https://forums.ni.com/t5/Example-Code/I2C-Bus-Communication-Example-Using-LabVIEW-FPGA/ta-p/3996143
Or Hirshfeld
אור הירשפלד
אור הירשפלד
Or Hirshfeld
Application Engineer
Certified LabVIEW Developer
SK- Electronika
+972-545844555
Or.Hirshfeld@SK-Advanced.com
il.linkedin.com/in/orhirshfeld
(4,533 Views)
