Digital I/O
what are the conditions where the daq may damage
hello
i am using daq 6014 for controlling one assembly.
i want to know what are tha conditions one should avoid to protect daq from damage
(3,111 Views)
Can you be a little more specific as to the environment in which you are working? What is the assembly you are trying to control?
Where is the card to be placed and what is the working temperature and shock and other parameters associated with the setup.
If you can share that then it will be easy to tell you the conditions.
Thank You.
Priyank Desai
(3,096 Views)
