Digital I/O
who dose limite the speed to 1ms in unstrobed IO mode with 653x device?
I'm using the 653x device and I'm running in unstrobed mode to have individual control on bits. But the toggling speed is just 1ms. Who is in charge of this? Is it LabView or the DLL function? If I switch to VB, can I get it to run faster? I want to get as fast as possible with this mode.
(3,044 Views)
Mostly this is system dependant and a function of whenever the operating system "feels like" executing the function call. I don't know if VB would run any faster or not. In this situation, you would be better off increasing the system priority of your program. If you are still unable to get the right speeds you want, you could switch to a which would enable you to be much more deterministic.
(3,044 Views)
